Author Topic: WATER FLANGE  (Read 1462 times)
Offline Ebordub71
WATER FLANGE
« on: 03 January 2011, 17:55 »
got a coolant leak coming from a water flange on the side of the cylinder head on my 8v gti.just want to know if its a common problem or just a case of changing it.cheers in advance :smiley:
Offline james_16v
  • 1986 Golf GTI 16v
Re: WATER FLANGE
« Reply #1 on: 03 January 2011, 18:16 »
Yeah common problem, they warp with age.
Should be just a case of undoing a couple of bolts and its off.
Make sure the new one has a new seal with it  :smiley:
Offline sparks03
  • Look at the veins in that
Re: WATER FLANGE
« Reply #2 on: 03 January 2011, 18:18 »
mmmmmmmm flange
<br />   Heaven is 13 feet long
Offline Ben Lessani
Re: WATER FLANGE
« Reply #3 on: 03 January 2011, 18:20 »
Very common, buy genuine.
Offline Ebordub71
Re: WATER FLANGE
« Reply #4 on: 03 January 2011, 18:50 »
cheers for the replys,will be at the stealers tommorrow to order a new one.you cannot beat a bit of flange......... :grin:
Offline danny_p
Re: WATER FLANGE
« Reply #5 on: 03 January 2011, 19:43 »
ummm fresh flange
all the VW's have gone bar 1.
Offline berni29
Re: WATER FLANGE
« Reply #6 on: 04 January 2011, 06:47 »
Hi
I recently changed mine and the new one cracked when I did it up so do not tighten too much. I do not think it was an original one though. Also the casting where the seal sits was not flat so needed a smear of metal putty to fix. All in all was a right pain for what should have been a simple job.
Berni
Offline dragonfly
Re: WATER FLANGE
« Reply #7 on: 04 January 2011, 10:14 »
Might be worth changing the seals around the sensors as these will be removed when you replace the flange.
