Author Topic: DV valves.  (Read 2624 times)
Offline Big Tone
DV valves.
« on: 03 January 2011, 11:28 »
Just seen this on Youtube
Mighty Car Mods - Blow Off Valves Mythbusted (SE02 EP03)
http://www.youtube.com/watch?v=Z_fG_b65WiU&feature=fvw
What do you think? apparantley no power loss with an atmospheric dump valve?
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline thatwillis
Re: DV valves.
« Reply #1 on: 03 January 2011, 13:05 »
I'm part of the turbo charged gang  :grin: haha and love it!
Thats an interesting vid
Offline simon20vt
Re: DV valves.
« Reply #2 on: 03 January 2011, 13:24 »
why would you want to install a bov on a non turbo, just buy a turbo car in the first place  :laugh:
Offline thatwillis
Re: DV valves.
« Reply #3 on: 03 January 2011, 13:31 »
just look how badass they looked in that daiwoo with the dv value  :tongue: :grin:
Offline alexd
Re: DV valves.
« Reply #4 on: 03 January 2011, 13:39 »
It makes sense about performance, and like he said, more modern engines don't really suffer from a great deal of lag anyways =]
BOV's ftw  :evil:
Offline Dan_GTI
  • GTi addict formally known as yoof
Re: DV valves.
« Reply #5 on: 03 January 2011, 13:49 »
dont be a woofta!
MK4 H&R 50MM SPRINGS FOR SALE £100 BRAND NEW
Offline Dave_IOW
Re: DV valves.
« Reply #6 on: 03 January 2011, 15:11 »
Dont think the arguement has ever been about power loss while installing a BOV.
When accelerating power will always be the same as video explains as both valves will be shut. What problem is on 1.8Ts is changing gear and metered air.
I have one fitted and the arguement against, which im pretty sure is correct, is that when you change gear, BOV vents to atmosphere which means less air in system, so over fueling happens for a short time after gear changes.
For those with new engines  :laugh: (mines AGU) you have 2 sensors, MAF and MAP and these must have similar air readings or will throw the ECU into limp mode?
I have tried,
007p cheap copy - spring was too weak, didnt get new one.
Baileys DV20       - doesnt work, needs to be twin piston.
Baileys DV26       - works OK on my AGU IMO. lots will disagree.
Forge 007p         - works great.
The dual piston valve works, i think, by only letting air vent to atmosphere under load, where as the DV20 or single piston ones vent to atmosphere as soon as throttle is released, and from my experience with AGU, this causes car to stall and run really rough.
Plenty will say what im doing is wrong, and messing my car up i expect, but this is all from my experience, on my car.
Im happy with how everything runs at the min, but i will be putting 007p back on for when i get to stage 2 as 1) R-Tech dont like them  :laugh: and 2) bored of the woosh  :grin:
Let the grilling commence  :laugh: :grin: :lipsrsealed:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline andc1
Re: DV valves.
« Reply #7 on: 03 January 2011, 15:28 »
i have a forge split r type which i can have as blow off or full circ, no issues at all, cant even feel any differance between them, i have an agu with a stage 1 remap at 197bhp
Offline richw911
Re: DV valves.
« Reply #8 on: 03 January 2011, 18:42 »
 :lipsrsealed:
Offline Dave_IOW
Re: DV valves.
« Reply #9 on: 03 January 2011, 19:40 »
:lipsrsealed:
Knew you wouldnt like this thread rich :laugh:
