Author Topic: conlog alarm system  (Read 2488 times)
Offline todd
conlog alarm system
« on: 03 January 2011, 10:51 »
anyone got one and do you know where the receiver is ?
Offline todd
Re: conlog alarm system
« Reply #1 on: 03 January 2011, 11:54 »
just found where they are apparently up behind the fuse box  :sad:     http://www.clubgti.com/forum/showthread.php?t=227084
« Last Edit: 03 January 2011, 11:56 by todd »
Offline The Doc
  • E63s Estate - Vito Sport
« Reply #2 on: 03 January 2011, 22:07 »
CONLOG now there's a name I aint heard in a long time  :wink:
Is it acting up? Where are you located?
Offline danmusic24
« Reply #3 on: 04 January 2011, 09:30 »
found a easy fix for conlog problems! thought mine was playing up stopping car from starting turned out to be ecu.but if you locate the alarm box which is located behind instuments on right hand side you just remove the four spade connecters and insert two fuses.this will  bypass it ....
Offline todd
« Reply #4 on: 04 January 2011, 10:12 »
Don't want to remove it just got a spare receiver for it wanted to know if I can change it and I got the fobs for it aswell my fob that's on it the button don't workjust want it working
Offline danmusic24
« Reply #5 on: 04 January 2011, 10:35 »
the  receiver is under glove box and the control box is behind instruments.i think you need to swap both parts.
Offline marky-gee
« Reply #6 on: 04 January 2011, 16:25 »
Rip the Cnut out they're more hassle than they're worth.
1997 GOLF GTI 2.0 (8v)
