Author Topic: Starting Advice on the 16v please.....  (Read 3413 times)
Offline walchy01
« on: 03 January 2011, 09:06 »
Hi there
Am I right in saying before I start rubbing down the contacts on my starter motor with sand paper etc do I need to disconnect the battery first???
Would u rub anything else down??? I am trying to resolve a starting problem.....
« Last Edit: 12 February 2011, 19:30 by walchy01 »
Offline Sam
  • Sam I am
Re: Advice on 16v please
« Reply #1 on: 03 January 2011, 09:18 »
Hi there
Yes, or you will die
Offline mk2bal
« Reply #2 on: 03 January 2011, 11:36 »
Oh yeah walchy my New 075 bosch hasn't made a difference to the slow start. My starter motors new as well...hmmm?? My toad alarm led flickers on startup, then gives me 9 red flashes, which I can't find out what means anywhere, but I'm thinkin its a low voltage/ bad earth sign..keep me posted with your workings
Offline walchy01
« Reply #3 on: 03 January 2011, 17:10 »
Will do mate, really sorry the starter motor hasn't fixed ur issue, I'll update as soon as I get a second to fiddle with it...... :grin:
Offline Ben Lessani
« Reply #4 on: 03 January 2011, 18:23 »
Did you replace the bell housing bush?
Offline mk2bal
« Reply #5 on: 03 January 2011, 18:29 »
I put a new starter on 6 months back, it had the cog on the end, is this the bush you mean?
Offline Ben Lessani
« Reply #6 on: 04 January 2011, 21:13 »
No, the bush is like a copper hula hoop that is inserted into the bell housing.
Offline walchy01
Advice on 16v starting issue please
« Reply #7 on: 12 February 2011, 19:26 »
Still not resolved this bloody dodgy starting issue, replaced the copper o ring where it connects to the gear box as it was significantly coroded well none existant to be honest :huh:
I was absolutley sure that was the issue, put everything back on yesterday and still no bloody joy....
Just as a reminder to the fault, the car tries to turn over but really really slowly as though i have a flat battery and i have not got a flat battery, it then sort of jumps into life and starts quickly  :undecided:
Would you now....
1. Get your starter motor refurbed??
2. Take it to an auto electrician?
3. Burn the car out because your as pissed of as i am??? :angry: :angry: :angry:
Really would appreciate further help, dont like the thing not running, it is only the 3rd car but i hate not to see it on the road cos i love driving it.....
Thank you once more
Offline Khare
  • The bear that khares
« Reply #8 on: 12 February 2011, 19:27 »
I had this on my mk3. New battery didn't sort it, neither did cleaning all the earths. Eventually the starter motor packed up and I had to replace it. Combined with a new battery and clean earths, a working starter motor feels like a new car turning on!
Offline bodga
  • F reg GTI 16v
Re: Starting Advice on the 16v please.....
« Reply #9 on: 12 February 2011, 21:11 »
If you have jump leads (heavy duty prefrably) use one of the leads connected to the -ve of the battery and to the starter case then try and start it see if its any better. also you could test the +ve side the same way. it will prove the starter is fooked or the earth or +ve connections are weak.
Mine used to be slow to not turning over when the engine was warm until i cleaned the contacts on the starter.
It doesnt turn over fast now but it fires straight away and these are high compression engines :wink:
