Author Topic: What you need for an ABF conversion.  (Read 45354 times)
Offline danny_p
« on: 03 January 2011, 00:06 »
1 )Cabel Change, Cabel Clutch, EFI
ABF engine (any)
ABF gearbox (any)
ABF 02A starter motor.
02A frount mount ( any )
02A gear box mounting bracket ( seat- tolado / cordoba )
02A cabel clutch actuator ( seat cordoba / tolado ? )
02A cabel shifter assembly
ABF 02A clutch and flywheel
driveshafts with 100mm cv's
ABF ECU
ABF engine loom
Inductive loop pickup
Imobliser transponder box
RFID Key ( preflably paired to transponder box and ecu )
02A speedo sendor for cable speedo ( pn to follow )
speedo cable
Ideal bits to fit
G60 rear engine mount
2 )Cabel Change, hydralic Clutch, EFI
ABF engine (any)
ABF gearbox (any)
02A gear box mounting bracket ( any )
02A clutch slave cyl
02A clutch master cyl
Hydralic clutch pipework
Brake fluid resovor for hydralic clutch
hydralic clutch pedal box
ABF ECU
ABF engine loom
speedo cable
Ideal bits to fit
3 )rod change, Cabel Clutch, EFI
ABF engine (any)
ABF gearbox (any)
020 starter motor. ( diesel ideal, GTi will do )
020 frount mount bracket ( any )
020 gear box mounting bracket ( any )
020 clutch cable
020  shifter assembly and linkages
020 clutch and flywheel 210mm
ABF ECU
ABF engine loom
020 speedo cable
Ideal bits to fit
4)  Rod change, Cabel clutch, mecanical injection (K-jetronic)
A SLAP WITH A BAT
all the VW's have gone bar 1.
Offline danny_p
Re: What you need for an ABF conversion.
« Reply #1 on: 03 January 2011, 00:07 »
garanteed to have missed a few bit but off th etop o head thats what you need for ABF conversion
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #2 on: 03 January 2011, 00:14 »
Danny your a star many thanks..
Offline dan_apps
  • too low for british roads!
« Reply #3 on: 03 January 2011, 11:27 »
needs to be stickied as this does come up now and again! good work Danny :afro:
Offline Diamond Hell
  • Opinions я Us
« Reply #4 on: 25 February 2011, 20:38 »
speedo cable
Passat Part 358957803G
Clutch actuation cable:
Seat Toledo ABF clutch cable for cable-change 'box with cable actuated clutch: 1L0721335G
Offline rich1977
« Reply #5 on: 07 June 2011, 23:48 »
so is there anything else needed if going from 8v diggi to 16v abf?
Www.Internet-ink.co.uk voucher code RL15 for 15% off all pens,toners and ink cartridges including cannon Epsom dell and hp.
  • Opinions я Us
« Reply #6 on: 03 April 2013, 22:52 »
Finally found all the part numbers for the cable clutch set up for 02A
You need a mix of parts from Passats and SEATS, as follows:
Speedo cable: Passat Part 358957803G
Clutch actuation cable: Seat Toledo ABF clutch cable for cable-change 'box with cable actuated clutch: 1L0721335G
Lever arm actuator assembly from VW or SEAT 02A 141 708B
Boot for arm from VW or SEAT: 02A141728
Tensioning bracket to hold the end of the cable outer from B3 Passat: 357199356
