The garage
Servicing
Topic: Servicing (Read 1734 times)
AlexMozza
Here all the time
Servicing
01 January 2011, 12:17 »
On the Mk3 GTi, Just wandering what things must be changed at the minor and major service. as my dash has started displaying IN 02.
Its due for an oil change but what else needs to be done like Fuel Filter, Pollen filter if fitted etc
What needs to be done for each, IN 01 and IN 02
2001 Satria GTi
Mini 25 Special Edition 1984 998
Formula 3 Mechanic
Deano2711
1992 VR6
Re: Servicing
01 January 2011, 13:47 »
Oil and filter, air filter, plugs and leads and check the pollen filter and then reset your service light. While you're on I would also clean the throttle body and breather pipes to make it run perfectly. That's what I do.
AlexMozza
Here all the time
Re: Servicing
01 January 2011, 13:54 »
Coolio. Thanks for that
2001 Satria GTi
Formula 3 Mechanic
Deano2711
1992 VR6
Re: Servicing
01 January 2011, 14:09 »
Also forgot to mention to clean the rotor arm and dizzy cap at the same time Mate
AlexMozza
Here all the time
Re: Servicing
01 January 2011, 14:27 »
I take it Emory papers fine for that?
2001 Satria GTi
Formula 3 Mechanic
Deano2711
1992 VR6
Re: Servicing
01 January 2011, 14:33 »
Yes Mate just need your contacts nice and clean and then wipe around the cap to remove any dust. You will feel the difference when you've finished the service
The garage
Servicing
