Author Topic: one for RJ maybe  (Read 1141 times)
Offline theclash
one for RJ maybe
« on: 30 December 2010, 21:23 »
i have ordered a injector seal kit for my 92 8valve thing is i havnt stripped my old ones out yet and dont know if the new ones are correct.    in the kit is 8x 15mm viton seals...4x bosch filter baskets...4x pintel caps and 4 spacer washers. is there 2 seals on each injector and are they the same size
Re: one for RJ maybe
« Reply #1 on: 31 December 2010, 08:16 »
if the kit is for a std bosh injector set then the seals will at least fit, but the spacers, filter baskets and pintel caps may not fit. there are several different styles of bosch injector which differ slightly at the tip end. but as long as your old bits are ok then just swap the seals over.
if it was me though i would get another set of injectors and get them professionally cleaned then do the seals when they come back
Offline danny_p
« Reply #2 on: 31 December 2010, 11:57 »
diy recon of your one and only set of injectors really isn't recomended.
all the VW's have gone bar 1.
