Author Topic: rev counter up and down,engine lumpy,oil light on?OH CRAP I NEED ADVICE,ANY HINT  (Read 1699 times)
Offline jiminbmth
  • brings back the sunshine!
OH CRAP I NEED ADVICE,ANY HINTS WELCOMED
hi,can anyone help,my mk3 2.0 8v has issues!!!
re counter up and down when engine is running even when revs are low,this stops,oil light flashes on and off then this goes out after a while,then rev counter again and so this goes on??
weird eh?
oil fine.
doesnt always happen,but unnerving when it does so dont want to drive for any distance.
thinking perhaps air module thingy?
jiminbmth ;)
Offline Deano2711
  • 1992 VR6
Do a search around the Mark 3 section Mate as this has been covered many times. Obvious things to try are cleaning the throttle body and breather pipes. Check the breather pipes for splits or damage. Then do a scan for fault codes as the crank sensor is another common issue.
Offline jiminbmth
CANT FIND THIS PROBLEM THO?
NOT BREATHER PIPES.
NOT THROTTLE BODY.
NOT CRANK SENSOR.
jiminbmth ;)
Offline danny_p
how do you know it's not the cranck sesnor
all the VW's have gone bar 1.
Offline jiminbmth
swapped with my other mk3 2.0!!
jiminbmth ;)
Offline jiminbmth
worried about the oil light flashing!
jiminbmth ;)
Offline jiminbmth
oh yer oh yer!
sorted,due to a brake in the wire ....doh :grin:
jiminbmth ;)
