Author Topic: misfire when in traffic  (Read 1353 times)
Offline gteyes
« on: 30 December 2010, 18:28 »
Hi guys,
Over the last week or so my 1990 8v gti Pb digifant has started to misfire and sometimes cut out when sitting in traffic. Car drives 100% on motorways no missing no lack of power only when I come into traffic and sitting at idle for a while engine starts to develop a misfire and cuts out restarts straight away give it a bit of acceleration and it splutters and then clears itself of the misfire,  happens only when engine is warm.
The only thing I have noticed when it starts to misfire if I pull the bonnet and leave it up it won’t happen but it I leave it closed it will start to misfire from this I would think its heat related thinking it could be possibly the coil heating up
Was just wondering if anyone has came across this before
Dave
Offline mattkh
Re: misfire when in traffic
« Reply #1 on: 31 December 2010, 21:50 »
Hi
I think its because you put your hand to the boot lever area.
Make sure all the relays, especially the fuel pump relay, are seated tightly.
Offline gteyes
« Reply #2 on: 01 January 2011, 10:21 »
have checked fuel system even done fuel pressure test all with in spec have also crosed over relay and driven stilll same fault happens
what i mean about bonnet open is if i pull in to the side open bonnet in the air, after about 2 mins car will run fine again only when i close it again with out moving misfire happens hagain with in five minutes
Offline golfmk4owner
« Reply #3 on: 02 January 2011, 15:14 »
Thats really odd mate. I wish i could give you advice but i only have sympathy on this one  :undecided:
I can only really relate misfires to ignition (sparks, coil, leads) and fuel (filter, injectors, pump).
But then you knew that already im sure!
2005 GT TDI 140 - Standard as F@k
