Author Topic: Screeching noise from steering - help needed  (Read 1516 times)
Offline barleymagrew
« on: 17 February 2005, 17:49 »
I have a Mk2 Golf GTI with power steering. When I turn the steering wheel from side to side, the car makes an almighty screeching noise - much like a slipping fanbelt.
I've checked the belt running the power steering pump and it seems tight enough.
Anyone got any suggestions?
Offline Dannyd
  • LOOK AT THAT VALVER GO!
Re: Screeching noise from steering - help needed
« Reply #1 on: 17 February 2005, 17:59 »
due for a change  :wink:
wacked up on scuby snacks!
Offline pegasus
« Reply #2 on: 17 February 2005, 18:02 »
Change the belt, its cheap enough to do, at  least then uv eliminated it as the problem. If the noise continues, it must be the pump  :sad:
1.8 20VT GTI
Offline AudiA8Quattro
« Reply #3 on: 17 February 2005, 18:58 »
Get someone to watch the pump pulley when you are turning the steering, do this with the car running.
You will soon see if the pump is knackered.
« Reply #4 on: 01 March 2005, 15:00 »
What will it be doing if the pumps knackered?
Judderi
« Reply #5 on: 01 March 2005, 15:34 »
It will be the belt. I had the same problem.
