General discussion
sump drain valve
Topic: sump drain valve (Read 1608 times)
macc70
Guest
sump drain valve
30 December 2010, 15:28 »
http://cgi.ebay.co.uk/Fumoto-drain-valve-replace-Peugeot-sump-plug-F111-/150528238292?pt=UK_CarsParts_Vehicles_CarParts_SM&hash=item230c2ea2d4
Whats the opinion of these things? Has anyone got one fitted?
Do they hang down too low?
Last question..IIRC I need a 14mm size thread??
If not a good idea I think Ill use the PELA 6000
Khare
Serious forum addict
The bear that khares
Re: sump drain valve
30 December 2010, 15:31 »
What's so difficult about removing the normal drain plug?
macc70
Guest
30 December 2010, 15:36 »
nothing wrong with doing it the old fashioned way
if you have the tools/lift. Just wanting to make life easy
Khare
30 December 2010, 15:38 »
My car is reasonably low yet if I drive onto a brick I'm able to get my hands underneath and undo the plug....No need for lift or anything.
Bellend
30 December 2010, 15:39 »
YAY! Yet more things to leak and more things to catch on speedbumps/kerbs/ice.
Nice one.
Where all my moneys went.
macc70
Guest
30 December 2010, 15:46 »
Im beginning to think this is a duffer and a FAIL
PELA it is then
Peej1981
Its Whats Under The Hood That Counts........
Reply #6 on:
30 December 2010, 21:28 »
Just strict to what it left the factory with, not sure how good these are and how reliable they?
www.bombercountydubs.co.uk
AudiA8Quattro
Forum addict
Reply #7 on:
30 December 2010, 21:58 »
What if you do happen to hit a speed bump? and open the valve!
Wayne
Sir Postalot
Reply #8 on:
30 December 2010, 23:09 »
I had one on a past car, the valve was at the top, great idea to be honest.
SoundillusioN
10k hero
Reply #9 on:
31 December 2010, 09:43 »
Quote from: Wayne on 30 December 2010, 23:09
Not sure on how it will fit on some cars, the sump plug is low enough as it is on a MK1 and I would worry about catching it on something, however, neat idea as it does prevent a couple of things, the need to replace washer so often and dropping the plug in the oil pan and then having to find it again.
Shaun
Now with added MK7
Forum Member Map
Mk1 Project Clicky
Mk1 Dub Rides Clicky
T25 Project Clicky
T25 Dub Rides Clicky
General discussion
sump drain valve
