Author Topic: Snow foam questions  (Read 2695 times)
Offline MAW73
  • Used to like Golfs :-)
Snow foam questions
« on: 30 December 2010, 10:41 »
I must have been a good boy as Santa brought me a Nilfisk Alto C 120.3-6 pressure washer as a stocking filler this xmas.
Anyway I've never owned a pressure washer before so looking forward to getting to grips with it on the car.
With regard to snow foam, is it good practice to snow foam the car every time you wash is??
I generally wash my car every week.
Also what's a good snow foam product to use??
Thanks in advance.
Martin :-)
2014 BMW F20 M135i, Auto
Offline dragonfly
Re: Snow foam questions
« Reply #1 on: 30 December 2010, 10:47 »
Worth doing if the car is dirty.  Plenty of retailers/sponsors on this forum who can supply good snowfoam.
http://www.golfgtiforum.co.uk/index.php?topic=173405.0
Offline georgeandpeppa
« Reply #2 on: 31 December 2010, 19:31 »
valet pro ph netural snow foam is good nice thick foam and pretty good cleaning to
Offline Uruk Hai
« Reply #3 on: 31 December 2010, 22:44 »
VP PH Neutral is a good foam and I do rate it but next time I need some I will be buying the Autobrite Magifoam, been hearing very good things about it and I gonna give it a go.
Offline SI74
« Reply #4 on: 02 January 2011, 14:43 »
Get a PH Neutral one then you can SF as much as you want as it shouldnt strip you wax.
Hers some from waxamomo
http://www.waxamomo.co.uk/productcart/pc/viewCategories.asp?idCategory=12
Offline Buck
  • Das Auto
« Reply #5 on: 11 February 2011, 12:52 »
Snowfoaming is worth doing each time you wash as the dwell time that this has on the surface of your car gives the chemicals time to loosen the debrisdirt that is on your paint.
when you rinse off, the car will be less dirty than when you started and importantly there is a reduced risk of you scratching/marring the paintwork as you have removed a lot of the contaminants.
A great new snowfoam that I am using is magifoam from www.autobritedirect.co.uk - it has a long dwell time and is the nearest I have seen to a touchless wash - I PW'd both cars last weekend, snow foamed with Magifoam, left to dwell for 15-20 mins and rinsed off - they looked virtually spotless although I didn't risk drying the paintwork only the windows.
