Golf mk4
Wazzzer
Adding Fogs????
Topic: Adding Fogs???? (Read 1322 times)
lowry_uk
GTI forum regular
Adding Fogs????
24 December 2010, 21:17 »
Hi guys
I am looking at getting the grill with fogs included.... Yes i have the headlights with the fos in them if that helps
My questions are
1. Is there any wiring as standard any behind the bumper
2. Will I need a relay etc
3. Will i need a switch of some sort
4. Is there any advice/tips or how to's
Cheers in advance guys
Golf MK4 PD130
18" Cades Tyrus Alloys after a Swap for some 3SDM's
andc1
Re: Adding Fogs????
24 December 2010, 21:31 »
dont it will look gay!!!!
all serious just tap off from headlight fogs! so when you pull the switch it will all come on! if you dont want headlight fogs on take the bulbs out!!!!
Wayne
Sir Postalot
Re: Adding Fogs????
24 December 2010, 22:07 »
Horrid things
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: Adding Fogs????
24 December 2010, 22:12 »
you dont need them...
Mk4 Golf GTI anniversary and mk6 golf tdi
navmk4gti
Forum addict
Re: Adding Fogs????
25 December 2010, 00:42 »
does actually look good.. i use to have some .. i wired mine by using exisitng fog light wiring from headlight and just took bulbs out in the headlight so works with the original switch
Website:
https://www.theonestopledshop.com/
Wazzzer
Moderator
10k hero
Golf GTI 1.8T AGU
Re: Adding Fogs????
25 December 2010, 09:40 »
You thinking of buying the fogs with the money you saved by NOT buying my springs you said you'd have?!
Bloody messer
1999 1.8T: R-Tech remap - 225bhp/256lb/ft : K03s : THS FMIC : THS PCR pipe : 2.5" stainless exhaust : THS FR3 Engine mounts : G60/VR6 clutch : Calibra Yellow injectors : VR6 MAF : Devils Own WMI : Forge 007p : Carbonio CAI : Leon Cupra R Brembos : FK AK Street coilovers : Votex skirts : Anniversary front : click --->
http://www.golfgtiforum.co.uk/index.php?topic=92175
vwblackmk4gti
Here all the time
Re: Adding Fogs????
Reply #6 on:
26 December 2010, 12:42 »
they make the car look, much better, go for it mate, and they are easy to fit. you jus use ur normal fog switch if u av them.
gives the golf a much better look.
thats why the manufacturer went bk to grill fogs with the mk5 and 6.
IDEAL UPGRADE
Golf mk4
Wazzzer
Adding Fogs????
