Author Topic: urgent advice!!!!!  (Read 2559 times)
Offline houston
Re: urgent advice!!!!!
« Reply #10 on: 24 December 2010, 11:02 »
i toldyou from the start to put washers on to check the clearance you need! 12 mm will need to be hubcentric, more money.
225 tyres and you wouldnt have had this problem, 235 are too wide for the fronts on mk4s
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #11 on: 24 December 2010, 11:04 »
yes new bolts are needed for 12mm spacers
Rim width won't really make any difference as it's the tyre touching not the rim...
You can still run the 225 or 215s on the 8.5J rim they will just have a bit of stretch
Offline p11jon
« Reply #12 on: 24 December 2010, 11:08 »
ye i know they will be hubcentric. the place i got these 5mm spacers from do 12mm and 15mm for rear 65 quid a pair. think i need to pay extra for longer bolts.when i tried the to 5mm together (purely for sizing up not running on),even with a 235 tyre it gave me about 2mm clearance on the suspension so if i get these 12mm ones for front i shudnt have to change the tyres will i???
Offline The Dave
« Reply #13 on: 24 December 2010, 14:13 »
I am one for thinking 19's are too big on a Golf MK4, 235 are bit too wide...
I think 225 width tyres will sort your problem.
Offline p11jon
« Reply #14 on: 24 December 2010, 15:52 »
ok thanks for advice. if bigger spacers dnt solve it i will strip the fronts and put 225's on aswell as 10mm spacer.then shud be fine. the 19's are hassle sorting but look nice. i llike 18's but some serious slamming and dish and i dnt wanna fork out thousands on wheels.the mrs has past her test so she will be using the golf alot.
Offline Grand Master Patch
« Reply #15 on: 24 December 2010, 15:59 »
There is another way :wink: Are you any good with a spanner?
Undo the top mounts and remove the helper spring from the coilovers,this will allow the height adjuster to sit way above the tyre while still allowing a decent drop thus solving the problem.
Offline houston
« Reply #16 on: 24 December 2010, 16:21 »
+1 do this, even paying someone to do it should be cheaper than the spacers, cos i can bet with a 235 tyre then your close to the arch?
Offline p11jon
« Reply #17 on: 24 December 2010, 17:11 »
cheers guys if all else fails i will give it a try gona just run the 18's over next few days had enough messing about with it this week.lol.
« Reply #18 on: 24 December 2010, 23:43 »
Sound advice or switch to 225 tyres.
Offline Gareth F
« Reply #19 on: 25 December 2010, 15:58 »
The words nail and head come to mind  :smug:
No SmOkE nO pOkE....
