Poll
were is the crank sensor on a mk3 golf engine
2 (50%)
were is the crank sensor on my mk3 engine
2 (50%)
Total Members Voted: 4
Author Topic: were is the crank sensor on a mk3 golf engine  (Read 15275 times)
Offline makkmarkmark
Re: were is the crank sensor on a mk3 golf engine
« Reply #20 on: 26 December 2010, 15:52 »
im not 100 % sure but i think ive found a relay that gose to the thermo i think just need to get a relay and find out for sure if you peeps have any more ideas would be great cheers mark
Offline SoundillusioN
« Reply #21 on: 26 December 2010, 17:35 »
I knew it was mechanical based just wondered for 8valves as my 16 does have one be it very basic.
Liam
Does it?... You're not confusing this for an ECU are you?
Hall Unit located in the N/S scuttle area of a MK1
Shaun
Offline lemski
  • 16v
« Reply #22 on: 26 December 2010, 17:38 »
Yeh doesn't run much. Got about 6wires going in to it via a plug. Ans shaun I always spell your name wrong and you've never corrected me.
Liam
« Reply #23 on: 26 December 2010, 17:59 »
Liam
It's just a transducer that varies output voltage to the sparks... Does not manage any timing or fueling like an ECU would.
I never notice, I get it all the time.
Offline lemski
  • 16v
« Reply #24 on: 26 December 2010, 18:23 »
Ahhh is that why there is a green knob on it that turns. Always wondered what that was used for and well I'll try and spell it right from now.
« Reply #25 on: 26 December 2010, 22:03 »
Hmmm, don't think so... there is no human adjustment on it...  not sure what you are looking at.
Offline lemski
  • 16v
« Reply #26 on: 26 December 2010, 22:05 »
Scuttle panel left hand side. Ecu holder as its been called. With the big box underneath and there's a strange green knob next to my vacuum pipe that turns. Don't know if it acyually does anything though as I turned it and turned it back. Just to be safe when I originally put the engine in.
