Poll
were is the crank sensor on a mk3 golf engine
2 (50%)
were is the crank sensor on my mk3 engine
2 (50%)
Total Members Voted: 4
Author Topic: were is the crank sensor on a mk3 golf engine  (Read 15325 times)
Offline SoundillusioN
Re: were is the crank sensor on a mk3 golf engine
« Reply #10 on: 23 December 2010, 13:33 »
hi shaun thats the one all right i am not getting fuel down the injectors i am getting fuel just in ignition prime (cold start bit)
so ive read its a big problem on k jet engines but not read any cures for this can you help cheers mark
Ok so you have a mk1 engine in a mk1 then  :grin:  You have the typical K-jet fuelled GTI engine for your information.
I have to keep popping to your other post for more info on what you have done so far....  You mentioned that petrol is coming out of the 2 injectors that go below the spark plugs... there are none there,  there are 5 in total, 4 at the back of the intake manifold (one of which Wayne was asking you to check for fuel) and one at the O/S of it (cold start valve)..... to help educate yourself a little before you do anything else, have a read and look at the pictures in this.. CLICK! ... you will find it very useful!
Shaun
« Last Edit: 23 December 2010, 13:34 by SoundillusioN »
« Reply #11 on: 23 December 2010, 14:16 »
Also check this
K-jet Trouble Shooting
 :wink:
Shaun
Offline makkmarkmark
« Reply #12 on: 23 December 2010, 14:49 »
thanks for that shaun i found that site once i new what engine it was and have printed it off will have a good go at it tomorrow hopefully it will just be something daft like the sensor plate sticking or something once again cheers for your advise will keep you informed
« Reply #13 on: 24 December 2010, 09:45 »
no problem, we got there in the end.....  If you need anything else you know let us know,
Shaun
« Reply #14 on: 24 December 2010, 12:10 »
hi shaun i think i have a electrical problem my cold start valve isnt getting electric so god nose what else isnt getting electric do you no if there is a fuse for this or ecu or something else cheers mark
« Reply #15 on: 24 December 2010, 12:58 »
I replied to your PM that you sent to me that was addressed to Wayne??  :smiley:
Shaun
« Reply #16 on: 24 December 2010, 21:58 »
K jet has no ecu, check all fuses and go from there.
Offline lemski
  • 16v
« Reply #17 on: 26 December 2010, 09:06 »
I always though k-jets had ecus. Or is it just the mk2 k-jets that do?
Neway have you checked the wires from cold start valve and traced back. This is if fuses didn't help
Liam
« Reply #18 on: 26 December 2010, 10:32 »
Liam
Nope no ecu on 8v's, it is a mechanical based system, very simple.
I believe the 16v had a ecu however
Offline lemski
  • 16v
« Reply #19 on: 26 December 2010, 14:10 »
I knew it was mechanical based just wondered for 8valves as my 16 does have one be it very basic.
Liam
