Author Topic: Ignition Coil  (Read 1240 times)
Offline Cyrill
Ignition Coil
« on: 21 December 2010, 20:25 »
Hi - I replaced the ignition coil on my 16v and unplugged three leads from one side and a double from the other.  When I came to put the new one on, I found the double and two of three leads on the other side.  I spent ages looking around the engine bay etc for the third lead but with no success, I searched on the floor and found the adaptor, any ideas where the three individual leads should come from so I can trace the missing one back?
Thanks
Re: Ignition Coil
« Reply #1 on: 22 December 2010, 08:43 »
there are only 2 leads per side ;)
3rd spade on the +ve side is a spare, which is covered up by a blank plug to prevent anything shorting out on that pin :)
Offline Cyrill
Re: Ignition Coil
« Reply #2 on: 23 December 2010, 12:23 »
Ha, I still have a way to go!  Thanks I was beginning to worry!
gixer1400
Re: Ignition Coil
« Reply #3 on: 26 December 2010, 15:45 »
hi there when you tighten the spades onto the coil dont tighten too much as the brass thread will easily shear off  :cry: and then your stuffed ,
have a happy new year  :cool:
