Author Topic: bonnet second catch snapped how to open bonnet  (Read 1707 times)
Offline paulwayman
« on: 21 December 2010, 14:43 »
i can open inside catch but not second one any way of doing it
Offline rio_gti
Re: bonnet second catch snapped how to open bonnet
« Reply #1 on: 21 December 2010, 14:56 »
yeah you just need to slip your hand in under the bonnet and push the little latch with your finger as far as i can remember i had to do it with mine for a few days!!!
Offline Waffs1984
  • Spacers are for chumps...
« Reply #2 on: 21 December 2010, 16:52 »
Mine did exactly this about this time last year. I found the latch was too hard to move using my hands or tools as its designed (i assume) so you can't quite get a screwdriver or something similar in to prise the lock open.
What i did in the end was pop the bonnet and prop it up as far as it will go with a bit of wood or similar. Then i fed some string through the hook on the top of the secondary catch and fed both sides of the string back over the passenger wing and pulled. I had to pull fairly hard but it worked after a couple of minutes of tugging. Turned out the cause was my lock was seized up, a good clean and some WD40 and touch wood its been fine till now!
My little black plastic catch pull thing has never been quite the same, it doesn't spring out anymore but that doesnt bother me as long as i can open the bonnet!
Mk4 GTi-T AUM l R-Tech Stage 1 l AP Coilovers l Forge 007p l New Style RS4's 18" l Toyo Proxies 4 l Hofele Bumper Grills l Silver Interior Trim l N249 Bypass l Front & Rear Powerflex bushes l Forge TIP l CAI l GolfGTi.co.uk Stickers l Catch Can Fitted & PCV System Deleted l Redstuff Rear Pads l More to come...
Offline paulwayman
« Reply #3 on: 21 December 2010, 17:05 »
thanks will try these ideas tomorrow got to go work now  :rolleyes:
thanks for the help  :smiley:
Offline paulwayman
« Reply #4 on: 22 December 2010, 10:58 »
thanks for the string idea it worked :wink: and for the bonnet the catch had jumped off the puller all fixed now  :smiley:
