Author Topic: bora vent illumination help  (Read 1511 times)
Offline andc1
« on: 21 December 2010, 14:24 »
picked up a set yesterday and bought a oem loom as well so it all plugs in to each vent as it should be im stuck on power to them, me and electrics do not mix so how do i power these babies up? is there a guide anywhere or someone point me in the rite direction!!! all im left with is a black wire and a yello wire which i presume is earth and power, where do i get the power from?
« Last Edit: 21 December 2010, 15:34 by Rhyso »
Offline vwfiend
Re: bora vent allumination help
« Reply #1 on: 21 December 2010, 14:44 »
Pop the light switch out by pushing it in while turning it a click clockwise then tap into the sidelight power cable. Check it with a voltage tester. There should be 12V present when the sidelights are on and 0V when its off
Offline andc1
« Reply #2 on: 21 December 2010, 14:47 »
ha ha i dont have a voltage checker!!!! just seen this and its saying plug the wires into dimmer switch!?
 brown and blue/grey, so am i correct in saying my brown to cars brown and my yello to cars blue/grey?
sorry to sound thick!!!!
http://www.carbasics.co.uk/vw_golf_mk4_bora_vents.htm
Offline Rhyso
« Reply #3 on: 21 December 2010, 15:05 »
Correct.  You tap into the blue / grey wire :afro:
Offline Dave_IOW
« Reply #4 on: 21 December 2010, 15:32 »
Blue/grey one yeah. Just done this with boost gauge  :wink:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline andc1
Re: bora vent illumination help
« Reply #5 on: 21 December 2010, 15:57 »
yello = blue/grey
brown= brown
sorry but im complete sh.t with electrics!!!!
Offline Rhyso
« Reply #6 on: 21 December 2010, 15:59 »
yello = blue/grey
brown= brown
That will do it
Offline andc1
« Reply #7 on: 21 December 2010, 16:00 »
cheers mate, dont wont firebrigade out this time if year!!!! :grin:
Offline Devilz
  • Cruisin is not a crime
« Reply #8 on: 21 December 2010, 16:29 »
yello = blue/grey
brown= brown
That will do it
I wired vents with light switch and vents only light when headlights are turned ON, not with parking lights. can i just remove the yellow wire from light swtich and connect with dimmer and leave black wire as earth with light switch??  :lipsrsealed:
Offline Dave_IOW
« Reply #9 on: 21 December 2010, 16:33 »
Cant see any reason why not, an earth is an earth right?
