Author Topic: Wiring Fk Angel Eyes  (Read 2496 times)
Offline thatwillis
« on: 20 December 2010, 17:23 »
So I've just got myself a pair of second hand Angel eyes.  :smiley:
I've had a good look around for wiring diagrams etc but i cant find anything. (Didn't get a copy when i bought them) Am i right in saying I need a separate wiring loom and relay for the halos?
There are 2 plugs coming out the back of the headlight that my original lights don't. I'm guessing they go to the battery or something to do with turning the halos on when you start the car?
If anyone knows of a good "how to" for them it would be great cheers  :smiley:
Also I have a set of lower fogs turning up soon does anyone the best way to wire them to the headlight fogs?
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
Re: Wiring Fk Angel Eyes
« Reply #1 on: 20 December 2010, 17:59 »
the 2 plugs will be the feeds for the halo rings themselfs... they should not need a relay if they are 12v you just need to tap them into your sidelight feed so they come on when you turn your lights on...
...Burn Rubber...Not Your Clutch...
Offline thatwillis
« Reply #2 on: 20 December 2010, 19:21 »
oh ok yeah that makes sence. Just found out the guy i got them off forgot to post the wiring loom... :rolleyes: So when I get that hopefully it should be self explanatory.
Is it as simple as plug and play or do i need to splice wires to connect the halos?
Offline Purely VAG
« Reply #3 on: 20 December 2010, 22:20 »
Sorry lol
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline thatwillis
« Reply #4 on: 20 December 2010, 22:46 »
haha no doesn't matter can't fit them in this weather  :grin:
Offline hainesz
« Reply #5 on: 21 December 2010, 16:50 »
all depends how it was wired before... if not you may have to splice into your wires... either way still a simple job... good luck
