Author Topic: Frozen suspension?  (Read 1903 times)
Offline logeyboy
Frozen suspension?
« on: 20 December 2010, 16:01 »
I drove to work this morning, only a few miles and noticed how rough the ride was. When I got out to check, the rear suspension had dropped several inches and there's no bounce to it at all.
As the day has gone on it has gone back up a little bit. Does this sounds like a have a leak and that it probably froze last night?
Offline rob.043
Re: Frozen suspension?
« Reply #1 on: 20 December 2010, 16:05 »
Could be broken springs, they will be more brittle at lower temperatures.
Offline danny_p
« Reply #2 on: 20 December 2010, 20:16 »
snaped spring  sounds like it's sat on the bump stops
all the VW's have gone bar 1.
Offline SoundillusioN
« Reply #3 on: 20 December 2010, 20:21 »
What susupension setup have you got on your car and how old is it?....  would be very surprised if it dropped so far due to being frozen!.... the above sounds more likely.  :sad:
« Reply #4 on: 20 December 2010, 20:47 »
Sounds more like a broken spring.
Offline Martz
« Reply #5 on: 20 December 2010, 20:57 »
Wait for the shreaded tyre, that'll be your spring broken then. More prone to break in this weather unfortunatley.
« Reply #6 on: 21 December 2010, 09:23 »
check in the boot to make sure the top of the shock hasnt pushed thru the upper spring cup
Offline Agreeable Slick
  • Unit
« Reply #7 on: 21 December 2010, 11:29 »
If it was this though, the car would still bounce. I assume you are talking about the circlip having popped off?
easy way to check is to open the boot, and just push the back up and down, will soon see the parcel shelf supports being pushed up and down if it has.
