Author Topic: wheel spins......  (Read 2763 times)
Offline rio_gti
wheel spins......
« on: 20 December 2010, 11:29 »
driving in the ice and snow i got very little traction (standard!!!)
only thing is that when the wheels spin the slightest bit (not a full on burn out!!) or the abs cuts in i get the dirtyest grinding noise almost like the teeth of coggs slipping.....  :undecided:
Does anyone else experience this or am i thinking i got a problem???
Offline mcgee9t2
Re: wheel spins......
« Reply #1 on: 20 December 2010, 11:35 »
i sometimes get this. not a problem so far for me.
if it aint broke dont fix it
Offline vwfiend
« Reply #2 on: 20 December 2010, 11:45 »
As above, I have the same but it'll probably stop when the snow does
Offline houston
« Reply #3 on: 20 December 2010, 11:49 »
i get a weird "twanging" noise from the drivers side front wheel when mine spins, but to me it sounds like the top mounts, there ok in the dry so nowt to worry about
Offline rio_gti
« Reply #4 on: 20 December 2010, 12:19 »
i'm not alone then which is good........ ill wait and see what happens in the dry  :rolleyes:
cheers guys  :smiley:
Offline Rhyso
« Reply #5 on: 20 December 2010, 12:26 »
Its your ABS kicking in (when you brake anyway)
If you have it, try turning off your ASR / ESP.  That will allow the engine to rev rather than have the power cut back
Offline alexd
« Reply #6 on: 20 December 2010, 12:51 »
Mine does this too, even if traction is off, i'm wondering if traction is ever FULLY off though? I hate thise noise, it doesn't seem right.
Offline Mikesps
« Reply #7 on: 20 December 2010, 12:54 »
I get it aswell  :undecided:
Offline rio_gti
« Reply #8 on: 20 December 2010, 13:50 »
dont think i got traction controll  :shocked:
dont have the ESP button so it means i havent??
your right alexd it doesn't seem right!!!!
Offline houston
« Reply #9 on: 20 December 2010, 13:56 »
traction control doesnt affect the abs tho, only way you can disable abs is by pulling the fuse and putting up with the dash light
