Author Topic: tick over issues  (Read 5006 times)
Offline steve69
tick over issues
« on: 19 December 2010, 20:26 »
sometimes my car ticks over ok then other times it wont tick over at all, when driving it goes ok but when slowing down for lights etc i dont know if it will cut out or if it will tick over, and ideas would be appreciated,ive only just bought the car so dont know how long it has had this fault, also it doesnt matter if the eng is hot or cold.
Offline Khare
  • The bear that khares
Re: tick over issues
« Reply #1 on: 19 December 2010, 20:50 »
Try cleaning throttle body and/or replacing ECU relay.
Offline steve69
« Reply #2 on: 19 December 2010, 20:59 »
were is the ecu relay located please
and do you know of any sites that show you how to do basic maintenance to my car.
Offline Len
« Reply #3 on: 21 December 2010, 12:55 »
ECU relay is with most of the relays above the fuses which is in front of the drivers right knee.
Not found any websites. I use a Haynes manual, or a Bentley.
Have a good read of the Info around here and you will get a good idea of whats needed.
There are specific threads about the cutting out issue.
www.sas.org.uk
www.the-ace.org.uk
Offline Khare
« Reply #4 on: 21 December 2010, 23:37 »
As Len said the Fusebox is by the right knee, there is a plastic panel with 2 green buttons on them, press them and the plastic panel will come off, revealing the fusebox. At the top it will have all the relays (Squares with a number on them). ECU relay is number 30, located at position number 3rd from top left
It simply pulls out. It's about £15 from VW (don't buy cheap copies, go to VW, it's cheap enough from there).
Try cleaning the throttle body first though, as it's free (just the cost of carb cleaner).
It could also be a dirty ISV, which would mean taking it out and giving it a nice clean with carb cleaner and then lubing it up with WD40, again just the cost of carb cleaner/WD40.  :smiley:
Offline steve69
« Reply #5 on: 22 December 2010, 05:28 »
Thanks
i will try these over the christmas break and hopefully this will sort the problem, and then i am looking forward to being able to really drive the car, thanks again much appreicated.
