Poll
I have a mk3 golf and im having problems with the head light switch
wot this problem is
1 (100%)
help needed
0 (0%)
Total Members Voted: 1
Author Topic: mk3 head light switch  (Read 1062 times)
Offline mk3driver1800
« on: 19 December 2010, 14:29 »
I cant get dipped beam only side lights this is my 5th switch all bulbs ok etc pls help sick of buying switches
Offline Khare
  • The bear that khares
Re: mk3 head light switch
« Reply #1 on: 19 December 2010, 15:28 »
It's obviously not the switches then  :rolleyes:
Have you checked the wiring loom? Is it all ok? Are the bulbs getting 12v or not?
« Reply #2 on: 20 December 2010, 10:33 »
dipped and main beam comes from the flasher switch, not the light switch. if main beam works, its the dipped beam wiring somewhere or the stalks. or the bulbs/fuses, but i assume you checked those already ;)
« Reply #3 on: 21 December 2010, 18:12 »
Hi thanks for your advice on this annoying situation ill check the stalks and wiring and hopefully thats should be the end of the switch buying saga lol thanks again ppl :-) :smiley:
