Author Topic: Wheel size question.  (Read 36153 times)
Offline p3eps
Re: Wheel size question.
« Reply #10 on: 19 December 2010, 18:04 »
Thanks for the links...
So the fist guide says generally a 5mm - 7mm difference should be ok.
If I'm going from 50 to 45 - does that mean that the wheels will be 5mm further in the arches?
And an ET60 would make the wheels 'stick out' and extra 10mm?
Golf R... 3 door, DSG, Leather, Reflex Silver, Black 19" Talladega Wheels, ACC, Parking Sensors, RNS510 with Dynaudio, Reverse Camera, Luxury Pack, Cruise Control & Fiscon Bluetooth.
Offline am1w
« Reply #11 on: 19 December 2010, 18:08 »
'If you reduce the amount of positive ET on the wheel then the vehicles track is widened and vice versa if the ET number is reduced. Straying too far from the original offset can be detremental as fouling to the suspension and bodywork can occur as well as eccess strain on wheel bolts or studs'.
« Last Edit: 19 December 2010, 18:52 by am1w »
Offline JonnyG
« Reply #12 on: 19 December 2010, 18:10 »
No they would stick out 5mm more
Current : Seat Cupra Lux, DSG, Magnetic Grey, Sept 2019
Gone :    Golf Mk 7 R, 5dr DSG, Pure White, March 2017
Gone :    Golf Mk 7 R, 5dr DSG, Tornado Red, March 2015
Gone :    Audi RS3, Daytona Grey, 7sp S-Tronic, Sept 2012
Gone :    Golf R, Rising Blue, 5dr DSG Mar 2010
Gone :    Golf R32, DBP, 5dr, DSG, Nov 2008
Gone :    Golf GTi ED30, Mar 2007
Offline p3eps
« Reply #13 on: 19 December 2010, 18:12 »
Hmmm... it seems near impossible to find a set of aftermarket reasonably priced wheels that have the correct offset.
45 seems to be the most common one available.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #14 on: 19 December 2010, 18:21 »
p3eps i posted a site link for you back on the 28th Nov on your R forum when you were asking about alloys. It is a very useful website to work out if it sticks out more or in more and other things.
P3eps have a play with
http://www.venommotorsports.com/library/tirewheelcalculator.asp
« Last Edit: 19 December 2010, 18:22 by Snoopy »
Garage:
35+ years of GTI ownership.
Offline p3eps
« Reply #15 on: 19 December 2010, 18:56 »
Am I looking at the wheel inboard and wheel outboard increase for that?  Its -0.196, and the tyre width difference is -0.39... so do these cancel each other out?
Offline p3eps
« Reply #16 on: 19 December 2010, 21:47 »
Found a set of Skoda wheels with a 51 offset with everything else correct.
They're 7.5j though - which I guess is better for winter tyres anyway?
What tyre size would go on a 18 x 7.5 wheel?  Still a 225 x 40 x 18?
If the ET45 fit and cause no problems then I'd probably rather have them.
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #17 on: 19 December 2010, 21:49 »
Tire & Wheel inboard and outboard tell you how much inward and outward difference there is to your reference wheel/tyre combo.
Garage:
Offline Snoopy
  • Moderator
  • Geoff.
« Reply #18 on: 19 December 2010, 21:50 »
The standard 18s on the R are 7.5" x 18 ET50 with 225x40x18 so more or less same as the skodas.
Garage:
Offline am1w
« Reply #19 on: 19 December 2010, 21:58 »
Snoops:
The 8" rim will stretch the tyre slightly in comparison to a 7.5" one.
Can one keep the tyre pressure the same as with a 7.5" rim?
