Golf mk4
Wazzzer
ecu reset
Topic: ecu reset (Read 1003 times)
stretch85
ecu reset
18 December 2010, 10:59 »
do i need to reset the ecu after fittting a new temp sensor
stretch85
Re: ecu reset
if so how do i do this
andc1
Re: ecu reset
18 December 2010, 11:42 »
not really, just unplug the battery for 30 mins and it will reset settings, like turning your pc off and on again!
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: ecu reset
18 December 2010, 14:33 »
Just install and drive buddy
Mk4 Golf GTI anniversary and mk6 golf tdi
northeast_gti-t
"1.8T AGU"
Re: ecu reset
18 December 2010, 15:47 »
no need to ecu reset just make sure you don't switch the ignition on with the temp sensor plug left off or you will store a code when you check with vag com
2000 Mkiv GTi 1.8T AGU
Golf mk4
Wazzzer
ecu reset
