Author Topic: another suspension question  (Read 1721 times)
Offline oakgreengolf
  • CAR FOR SALE PM FOR FURTHER INFO
« on: 18 December 2010, 08:36 »
Right I'm going to be getting the valver back out in the spring. Current setup comprises of hottuning coilovers and mk3  top mounts. I opted for coilovers due to the fact I'm running 16 inch alloys and have a heavy lpg tank in the boot.  So it was easy to get the correct ride height.  However I'm fed up with the firm ride and want to go back to shocks and springs. I have a set of koni shocks which appear ok springs are not good so would like some advice on which springs to choose. Or should I just opt for a new setup. Any help or recommendations greatly apreciated :smiley
Offline The Mighty Elvi
  • I'm better than you today.
Re: another suspension question
« Reply #1 on: 18 December 2010, 10:40 »
Koni + eibach FTW.
Get MK3 ones to cope with the extra weight.
See Haribos thread.
Offline Ben Lessani
« Reply #2 on: 18 December 2010, 10:44 »
I was looking too - gave up and bought another car!
Your choice of good (cheaper) shocks is actually fairly limited. The Koni's are about £130 per corner IIRC. I was looking at a nice Eibach+Koni set up around £6-700.
There's some fairly valuable info here http://www.golfgtiforum.co.uk/index.php?topic=168376.0
« Reply #3 on: 18 December 2010, 14:18 »
Ive got the shocks so just need the springs. just want it to sit right otherwise i'm wasting my money
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 18 December 2010, 15:26 »
Eibach for me... Nice compromise for ride...
For More Info Click To See;
Offline rob.043
« Reply #5 on: 18 December 2010, 17:03 »
RJ reckoned the MK3 front mounts raised the front by 10mm, and the weight in the rear may really bu**er up the height there too. So its a risky manoeuvre removing the coilies.
Id vote for the Eibach springs too. Venom motorsport seemed to be the cheapest when I got some recently. But keep the coilies and be prepared to take a loss selling the springs on ebay if it looks odd!
« Reply #6 on: 18 December 2010, 18:42 »
Due to the extra weight in the rear I was thinking maybe the mk3 springs would be best. Eibach do a 30 mm drop in these.
Offline rob.043
« Reply #7 on: 18 December 2010, 19:08 »
would think mk2 front, mk3 rear to try to keep the front down. But thats not really a kit option!
« Reply #8 on: 20 December 2010, 10:20 »
I did read the mk3 mounts raised the car, but it didnt seem to on mine. well, maybe a small amount but i think that was more to do with the old ones being buggered than anything! certainly wasnt as much as 10mm anyway
Offline lemski
  • 16v
« Reply #9 on: 20 December 2010, 10:26 »
Surely if you measure how far down your coilovers are you can then order springs to match and it will sit the same as it does now.
