Author Topic: Torque wrench for oil change?  (Read 3339 times)
Offline paul69
« on: 16 December 2010, 21:14 »
I intend to do an oil change myself for the first time this weekend, and according to Haynes I need to do up the sump plug with a torque wrench. I don't own, and have never used a torque wrench, so is this actually necessary, and if so, what size do I need?
Offline The Mighty Elvi
  • I'm better than you today.
Re: Torque wrench for oil change?
« Reply #1 on: 16 December 2010, 21:23 »
Just do it tight enough not to destroy the copper washer.  :grin:
Offline Ben Lessani
« Reply #2 on: 16 December 2010, 21:24 »
Well, its a worthwhile tool to own - but I can't say I've ever torqued a sump bolt! IIRC its about 20 NM which is just past hand tight, remember to change the copper washer on the bolt ;)
This is a pretty reasonably priced wrench with a good range.
http://www.machinemart.co.uk/shop/product/details/cht141-1-2in-drive-torque-wrench/path/ratchets-torque-wrenches-2
And one of these for removing the oil filter
http://www.machinemart.co.uk/shop/product/details/cht430-chain-oil-filter-wrench
When putting in the new oil filter, fill it full of oil, then rub a bead of oil around the top - then tighten it hand tight only.
Offline Horney
« Reply #3 on: 16 December 2010, 21:26 »
Do it up tight, but not effing tight. Steel sump on your car I think so not too much chance of fecking it up.
Nick
Offline Horney
« Reply #4 on: 16 December 2010, 21:28 »
Eh? I thought that's what a screw driver and a hammer were for?
Nick
Offline Ben Lessani
« Reply #5 on: 16 December 2010, 21:30 »
Lol - only if you want a face full of oil!
Access is tight on the MK2 to fit a cup type tool on there, but the chain wrenches work a treat!
Offline paul69
« Reply #6 on: 16 December 2010, 21:56 »
Ok thanks for that :smiley:
« Reply #7 on: 17 December 2010, 00:02 »
Yep that is I have ever done.
Offline AudiA8Quattro
« Reply #8 on: 17 December 2010, 23:57 »
I do actually usually use a torque wrench, even on a sump plug.
Ben, why fill the filter with oil before fitting? surely that going to be messy.
« Reply #9 on: 18 December 2010, 09:34 »
I have always done the same, helps with priming up it back up.
