Author Topic: Some advice from the tdi geeks!  (Read 1396 times)
Offline Dan_GTI
  • GTi addict formally known as yoof
« on: 16 December 2010, 20:30 »
well my pride and joy is sold and gone and already regretting it but i need a diesel. been looking at tdi 130 golfs and boras but as im a petrol man can someone tell me what to watch out for?
MK4 H&R 50MM SPRINGS FOR SALE £100 BRAND NEW
Offline Adam
Re: Some advice from the tdi geeks!
« Reply #1 on: 16 December 2010, 20:50 »
Clutch and boost pipe lugs.
Down Hill From Here.
Offline Gareth F
« Reply #2 on: 20 December 2010, 23:08 »
DMF is a big thing, clutch and DMF are about £900 in parts before you even think of labour.
No SmOkE nO pOkE....
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #3 on: 20 December 2010, 23:10 »
smf can be fitted no ??
Offline flamotronic
« Reply #4 on: 20 December 2010, 23:27 »
I wouldn't touch SMFs with a barge pole if you don't want vibrations entering your car. Even if you can cope with the vibrations they are not very healthy for the gearbox!
In response to the OP, check the response of the turbo for failure, i.e. the usual tell-tale signs of failure (oil consumption, smoke, unfamiliar noises, etc.). Oh, and the common and well-noted PD150 'chocolate' camshaft can affect PD130s too (even if some disagree or if it isn't a common fault for those engines), so if you are able to, whip off the cam cover to check for signs of wear and tear. If so, walk away, or budget at least a grand for repair!  :shocked:
Finally, make sure the cambelt has been changed as per service history.
PQ34 Wolfsburg Type 1J Turbo-direct Injection Pumpe Duse 115
A work-horse of a vehicle; this and that going wrong, but it's still a Dub, 'aint it?!
Offline Adam
« Reply #5 on: 20 December 2010, 23:38 »
With regards to the chocolate camshafts they are known to go on the 130PD as well. Only way to tell is a ticky idle on cold start and to remove the cam cover and inspect the cam lobes and tappets for wear.
Other than the other common faults for the mk4 (Windows, water pump and the rear wiper motor) there really isn't too many more other than what is listed above.
