Golf mk2
Which gearbox?
Topic: Which gearbox? (Read 1278 times)
HuwMk2
Here all the time
Which gearbox?
16 December 2010, 19:21 »
Hi all. Need a new gearbox for my 1992 8v. Will any 8v gti gearbox fit or do I need one with a specific code?
Also, out of interest, are 16v and 8v boxes the same?
Thanks,
Huw
Ben Lessani
The poor mans MK2 Haynes author
Re: Which gearbox?
16 December 2010, 20:02 »
They have a different sized input shaft IIRC.
8v 020 should do you
tony_ack
Re: Which gearbox?
16 December 2010, 23:11 »
020 AUG is a like for like, but the earlier ACD box from the pre-90 8v GTI should fit as well.
The AUG has a slightly taller 2nd so that you can get to 62mph without changing to 3rd
1992 VW Golf MK2 GTI
1995 VW Corrado VR6
rubjonny
10k hero
Hello, my name is John and I'm a dub addict.
Re: Which gearbox?
17 December 2010, 08:28 »
16v is same as the earlier ACD box in terms of ratios, except it has a shorter 5th so higher revs when cruising on motorway plus slightly lower top speed. there isnt a massive amount in it though:
http://www.scirocco.org/gears
as ben says 16v box has a bigger input shaft, so need a 16v clutch friction disc. you'll want to put a new clutch on unless its pretty new while the box is off anyway. 2.0 8v gearbox fits as well, has taller ratios than the mk2 gti boxes and has the same input shaft as the 16v mk2 box.
when you swap box i would replace the input shaft seal, plus the pushrod bush & seal
Golf mk2
Which gearbox?
