Author Topic: igniton amplifier part no  (Read 1281 times)
Offline stretch85
« on: 16 December 2010, 19:20 »
seen as the maf hasnt cured my misfire going to try this anyone got part number for one for agu
Offline sonyboy
Re: igniton amplifier part no
« Reply #1 on: 16 December 2010, 19:38 »
it is 4D0905351, you can find it on german ebay, there is best price for original part, price/OEM balance ;), all others are same chinese or some some manufact...
Offline stretch85
« Reply #2 on: 16 December 2010, 19:53 »
any idea how much this is likely to cost??? and is it just plug and play??
Offline mattkh
« Reply #3 on: 16 December 2010, 20:51 »
Hi
Ignition amps either work or they dont. Yours is working.
I would try changing the temperature sensor used by the ECU first.
Offline MaXXeH
  • Golf MK5 GTI
« Reply #4 on: 16 December 2010, 21:40 »
Hi
Not true,  mine run like poo untill i changed it.
Offline sonyboy
« Reply #5 on: 16 December 2010, 22:04 »
around 20Eur is fine price.
i would not agree with that it is working or it is not working. Everytime when i just touch cables or plugs from ignition amp. i'm getting small change in engine run or small shakes.
Offline Purely VAG
« Reply #6 on: 17 December 2010, 09:43 »
If you need an amp, Drop me a call/text 0792322024
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline richw911
« Reply #7 on: 17 December 2010, 19:08 »
+ 1 on the temp sender as said in your other thread  :smiley:
Offline stretch85
« Reply #8 on: 17 December 2010, 20:11 »
ok changed the ignition amp and it aint that, have got a new temp sensor but the guage is reading fine,was thinking of trying a coil pack aswell, running out of ideas and is costing a fortune need to get this sorted,code reader is still sayin no fault codes
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #9 on: 17 December 2010, 21:45 »
going through the exact same thing with my mates Audi at the mo mate, unfortunately AGUs don't show up a lot of faults...
