Author Topic: not happy!!!!  (Read 1772 times)
Offline stretch85
not happy!!!!
« on: 16 December 2010, 17:34 »
still struggleing with this misfire :cry:
scanned car with code reader, no faults which according to past experience on this forum leads to maf or ignition amplifier. so i un plugg the maf and take down the road, down on power obviously but misfire goes away. so i replace the maf with a genuine item, car ran fine when first set off not even a splutter(engine cold),but as the temp began to rise i got a splutter and then it was back to misfiring again, still showing no fault codes . any ideas??? 99 agu by the way
Offline tech1889
  • Mk2 GTI FTW !!
Re: not happy!!!!
« Reply #1 on: 16 December 2010, 17:40 »
Genuine maf ??
Offline stretch85
Re: not happy!!!!
« Reply #2 on: 16 December 2010, 17:48 »
yeah shelled out £105 plus surcharge for the bosch item, think i made a mistake buying this car, its the car from hell
Offline richw911
Re: not happy!!!!
« Reply #3 on: 17 December 2010, 18:52 »
Temp sender? and as you said ignition amp  :undecided:
jamie16v
Re: not happy!!!!
« Reply #4 on: 17 December 2010, 18:54 »
Offline stretch85
Re: not happy!!!!
« Reply #5 on: 17 December 2010, 20:13 »
changed the ignition amp today, still no joy. have got a temp sender but the guage is working fine,running out of ideas
Offline richw911
Re: not happy!!!!
« Reply #6 on: 17 December 2010, 20:16 »
Somtimes the gauge works fine but it can still be faulty  :wink:
Offline stretch85
only missfires when warm???
« Reply #7 on: 17 December 2010, 20:19 »
my car runs fine when engine is cold, but gets worse as it gets warm,some times it will pull all through the revs other times it misfires from 2grand upwards .changed maf and ignition amp for genuine items still no joy, temp guage working fine no engine codes???
Offline new to vw
Re: not happy!!!!
« Reply #8 on: 17 December 2010, 23:09 »
Crank sensor poss or cam sensor
5 door 1.8t AUM
Offline stretch85
Re: not happy!!!!
« Reply #9 on: 18 December 2010, 10:36 »
ok changed the temp sensor this morning for the green one still no joy. gonna buy a coil pack today and swap that over to eliminate that, would crank sensor or cam sensor not show up on code reader
