Author Topic: HELP LOST MY KEYS  (Read 1627 times)
Offline keithtenerife
HELP LOST MY KEYS
« on: 16 December 2010, 17:19 »
Hi all i have lost my keys for my gti 3 1996 i know i cant just buy a key but can anyone tell me what i need to get from the scrappy i.e locks do i need any ecu etc etc many thanks Keith :cry: :angry: :cry:
Offline sharki786
  • GOT BOOST??
Re: HELP LOST MY KEYS
« Reply #1 on: 16 December 2010, 18:21 »
think on 96 + the ecu ignition and key have transponders. so without the chip in key your fooked and need all 3 i think.
*****MK3 Anniversary*****
*****MK4 GTI T*****
« Reply #2 on: 16 December 2010, 18:49 »
Thanks for the fast responce would you know where they are located and how many of each.
Offline Khare
  • The bear that khares
« Reply #3 on: 16 December 2010, 18:54 »
All you need is a key (any key with a chip in it) and the matching ignition lock.
Then via vagcom and vagtacho you can recode the new key's chip to the ECU immobilizer.
Offline GAM2000
« Reply #4 on: 16 December 2010, 19:31 »
Iv only got one key, so if i got another key it can be recoded with out changing more bits
« Reply #5 on: 17 December 2010, 08:21 »
can only recode if you have got the SKC, and you can only get that if you have a matched key in the ignition :(
if you do get a new chipped key make sure you get the transponder box to match, then you can match your ecu to it with vag-com.  the problem comes when trying to match a key to a transponder box, this is when you need the SKC.
vw can cut you a new key based on your vin, and can also code it to your transponder box but this means transporting the car to them.  VW can request an unlock code for the immobiliser box which gets around the SKC problem.
Offline madmanmart
« Reply #6 on: 21 December 2010, 22:24 »
I could do you a good deal on a:
ECU
Transponder
Key + chip
Ignition Barrel
Door lock
All from a 1997 GTI engine code AGG
Your sorted then ;)
Mk3 Golf 3dr GTI 16v
Mk3 Golf Cabriolet TD
20vt Corrado track car project
