Author Topic: Gurgling noise when engine is turned off  (Read 4456 times)
Offline AlpineAddict
« on: 16 December 2010, 14:51 »
Hi there
I have noticed that when I turn the ignition off, after driving my V5, there is a gurgling noise evident. This can be heard inside th car and sounds like bubbling water/oil... I have lifted the bonnet and the noise is clearly heard form the back of the engine somewhere, almost by the windscreen.
The noise last around 5 mins or so after turning the ignition off????
Any ideas folks? Is this normal, as I swear it never used to do this?
Thx and Happy Xmas folks
jamie16v
Re: Gurgling noise when engine is turned off
« Reply #1 on: 16 December 2010, 15:34 »
any other symptoms like overheating or no heat from blowers?..
Offline dolphinfriendly1012
« Reply #2 on: 16 December 2010, 15:41 »
There is an auxiliary water pump fitted to the v5 and v6 engines. This comes on when the engine is turned off and continues to circulate the water for 5 - 10 minutes. I suspect what you can hear is the water being pumped around the system as is slowly cools down.
« Reply #3 on: 16 December 2010, 15:52 »
Hi
No other symptoms at all... no overheating or anything.... Think I will go for the water pump option... thx for this  :smiley:
Offline mcgee9t2
« Reply #4 on: 16 December 2010, 16:18 »
Didn't think you would have been able to hear the water getting pumped around though?
Or I've never heard it when people I know have turned there v5 and 4mo's off?
« Reply #5 on: 16 December 2010, 16:24 »
Never used to hear mine, its only been during this really cold weather that it has been so noticeable, soon as the pump stops noise stops.
Offline the_stink
  • A3 140 TDI
« Reply #6 on: 16 December 2010, 18:50 »
never heard anything like that with the R32 just the fans would kick in
Offline mcgee9t2
« Reply #7 on: 16 December 2010, 19:13 »
does this cooling  system have its own water supply? could be that its leeking water therefore is pumping air and water through making the gurgling noise?
« Reply #8 on: 17 December 2010, 00:13 »
Normal really, it is the auxiliary water pump 99% sure on that  :smiley:
« Reply #9 on: 17 December 2010, 10:35 »
Thx all... I am putting it in for a service in the New Yr so I will get it checked then... Thx again folks
