Author Topic: upgraded headlight loom guide  (Read 3069 times)
jamrock
« on: 14 December 2010, 12:24 »
http://www.vintagewatercooleds.com/tech/Techtips/Timbotechnotes/headlight/Headlight.htm
after seeing chris and SoundillusioN threads on upgraded head light looms i found this when search online as the mk2 lights are sh!t!!
does it look right as i have no idea and am tempted to buy a ready made one
Offline X4MGS
  • VAG Parts SNOB!!!
Re: upgraded headlight loom guide
« Reply #1 on: 14 December 2010, 13:47 »
Looks a good write up...
Will be using it to make my own up!!
For More Info Click To See;
Offline The Mighty Elvi
  • I'm better than you today.
Offline Adam
« Reply #3 on: 14 December 2010, 14:02 »
Could you use this if you snip the HID ends off this? Just a thought  :undecided:
Down Hill From Here.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #4 on: 14 December 2010, 14:16 »
Offline h8v
« Reply #5 on: 14 December 2010, 14:21 »
Hi Adam,
I wouldn't use that set-up if I were you.  It only has one relay and those cables don't look any heavier than the ones in the original wiring loom.
What you're looking for is thick cables and either two, or perhaps four, relays to minimise voltage drop between the battery and bulb.
h8v
« Reply #6 on: 14 December 2010, 14:49 »
aye main thing is ideally you want 1 fuse and relay per side for the dipped beam, otherwise if 1 goes you'll loose all the lights. relay for main beam isnt so necessary but i always add one for completness
Offline Sam.
« Reply #7 on: 15 December 2010, 19:50 »
I relay'd main + dip beams for both sides individually, means i'll only loose 1 function (dip/main) if a relay diesĀ  :grin:
Offline SoundillusioN
« Reply #8 on: 15 December 2010, 20:12 »
That write up is good.  Don't buy cheap ready made kits, you may as well stick with what you've got.  Also wouldn't bother with the HID wires.  Its better to just get exactly the length you need or more at the gauge of your choice, you're own connections and do it from scratch.  Easier than you might think.
Shaun
Offline h8v
« Reply #9 on: 15 December 2010, 20:39 »
Make a list of all you need from www.vehiclewiringproducts.co.uk and price it up.
They have all you could possibly need; and while you're at it get some high capacity starter cable or flexible welding cable and ring terminals to do a proper engine earth and starter motor connection, to guarantee a good start in the cold weather.
A few spare fuses and whatever to make the most of the carriage cost, and make your life easier in the future!!
(I've no connection with them)
h8v
