Author Topic: Can you use....  (Read 1563 times)
Offline new to vw
Can you use....
« on: 14 December 2010, 12:11 »
Standard springs with shortend shocks.....My shocks are shot and i have found a set of jamex ones for less money than standard shocks from a motor factors....
Any help... :grin: :grin:
5 door 1.8t AUM
Offline vwprime
Re: Can you use....
« Reply #1 on: 14 December 2010, 12:33 »
Sounds like a good time to lower the car me things with some new springs also  :wink:
If it was me i wouldn't get shorter shocks as yor car will be a even more like a boat.
TRANSFORM, & ROLL OUT!
Re: Can you use....
« Reply #2 on: 14 December 2010, 12:42 »
Not the best idea really.
Offline mcgee9t2
Re: Can you use....
« Reply #3 on: 14 December 2010, 12:46 »
you could do it yes, would it be a good idea no.
just buy some springs with it, your getting jamex shocks, jamex springs are only about £50 for all 4 .
Offline tg1
Re: Can you use....
« Reply #4 on: 14 December 2010, 13:54 »
i'd avoid jamex if you can. bouncey bouncey
Offline The Dave
Re: Can you use....
« Reply #5 on: 15 December 2010, 00:23 »
I run Jamex shocks and springs on my car.
Not bouncy, not too stiff... pretty smooth comfy ride all in all, which is why I'm reluctant to move to cheap coilies :)
Offline Chris36
Re: Can you use....
« Reply #6 on: 15 December 2010, 00:52 »
Not a good idea - go for a set of standard shocks if thats your budget. Id much rather go for a set of Eibach springs then jamex BTW - some people cut off a coil to fit - but it will ruin the handling.
Offline Dave_IOW
Re: Can you use....
« Reply #7 on: 15 December 2010, 17:59 »
Ive upgraded and bought coilovers, if you do decide to do this, you can have my springs posted for 30 quid, thy are Jamex. I quite liked them  :lipsrsealed: but wanted o go low  :wink:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
jamie16v
Re: Can you use....
« Reply #8 on: 15 December 2010, 21:07 »
i bought jamex -35 mm kit and i am more than happy with it. i have had it nearly  12 month or so now and i bought it because my original springs had snapped. oem springs are sh!te anyway.
Offline The Dave
Re: Can you use....
« Reply #9 on: 15 December 2010, 23:54 »
I must have got myself a lucky good set then  :cool:
