The garage
mkII not starting
Topic: mkII not starting (Read 13361 times)
jhirst
Just got here
mkII not starting
04 June 2003, 00:30 »
I have had a 16valve mkII engine put in to replace an 8valve. It has so far taken 20 months and I am now on my third mechanic. The (new) spark plugs are producing reasonable spark and there is fuel coming through the injectors but the car will not start. When turning it over it pops as if trying to start but no joy. Help. I fear for my sanity!
Last Edit: 01 January 1970, 01:00 by 1055631600
mk1
2ltr16v turbo (now with programmable EFI)
Re: mkII not starting
04 June 2003, 01:34 »
Check that the cam and ign. timing are ok. Then check the fireing order at the distributor. Should go, hope this helps,
Steve.
http://www.geocities.com/mk1turbo16v/golf_turbo.html
ajh
04 June 2003, 13:34 »
Check the little electical unit (can't remember what its called) under the plastic at the top left hand side of the engine bay.
The garage
mkII not starting
