Author Topic: R-Tech 1.9 tdi VNT Turbo Sticky Vanes overboost / limp mode fix  (Read 9053 times)
Offline RTechUK
  • R-TECH OFFICE 01455 617233
R-Tech VNT sticky turbo vanes repair
In 90% of cases this will stop overboost limp mode, return better MPG and make the car more responsive and safe.
 PART 1 > http://www.youtube.com/watch?v=jgqDEBEOF_4
PART 2 > http://www.youtube.com/watch?v=UWyN53N_uMI&feature=related
PART 3 > http://www.youtube.com/watch?v=dhZYCUKOVRc&feature=related
PART 4 > http://www.youtube.com/watch?v=43W7Abmwhhk&feature=related
http://sticky-vnt.co.uk  http://removal-dpf.co.uk Midlands
« Last Edit: 11 July 2012, 20:59 by RTechUK »
 01455 617233
Offline torquetastic
Re: R-Tech 1.9 tdi VNT Turbo Sticky Vanes overboost / limp mode fix
« Reply #1 on: 14 December 2010, 16:42 »
Is this really that common that it will sort out limp for all of us that have limp and poor mpg?
The main question is how much is it to get done and how long would you need the car for?
Anyone used these guys for this work in the past? I know you guys have all been mapped by r-tech but anyone specificially had this work done as it seems like a tricky job. Anyone give any feedback about this job?
Is the Innotec not any good anymore then? I read loads over the summer about the Innotec service you guys provided which was supposed to be really good for £90 including the Innotec kit.
Offline vwprime
« Reply #2 on: 14 December 2010, 18:43 »
Really nice Video report the Nick and very intresting to se how it all works and moves ( or dosent in the begine stages)
How did the turbo go after all this? Was it as it should be in the end?
Also exuse my ingorants but was does VNT stand for? Verable ????? Turbo?
TRANSFORM, & ROLL OUT!
Offline BJD
  • G2 GTI 16V - G4 TDI 130
« Reply #3 on: 14 December 2010, 18:59 »
Variable nozzle turbocharger? I think.
Basically it has adjustable vanes in the turbine housing to redirect exhaust gasses to improve spool up, and reduce lag
« Last Edit: 14 December 2010, 19:02 by BJD »
Offline asif
« Reply #4 on: 15 December 2010, 22:26 »
For someone that has possible VNT sticky vanes what is the best advise on how to drive with it whilst you don;t have funds to get it fixed?
Can you do any damage to the car whilst driving with sticky vanes?
MK7 GT Bluemotion Tech TDi 150
Offline pipbailey
« Reply #5 on: 16 December 2010, 11:25 »
Yes, the turbo is working at 150% or flat out maybe seeing upto 40psi , so turbo seal will fail, can split intercoolers, boost controller working overtime trying to bring the boost down, poor MPG,  too much cylinder compression head gasket fail.
Offline RTechUK
We have opened a new two workshop bays just for VNT cleaning and DPF issues cleaning and removal
http://sticky-vnt.co.uk  http://removal-dpf.co.uk Midlands Leicestershire / North Wales and Chester
 01455 617233
Offline asif
