Golf mk2
Gearknob change
Topic: Gearknob change (Read 1471 times)
paul69
GTI forum regular
Gearknob change
12 December 2010, 22:49 »
When I bought my digi it had this gearknob in it
I want to change back to a standard black golfball gearknob but I can't get the above one off. It won't twist and I am nervous of using any tools on it in case I damage the gearstick. Would it have been glued on or would it have come attached to this gearstick, which I would have to remove in order to change the gearknob?
Mitching
Here all the time
Re: Gearknob change
12 December 2010, 23:06 »
Could just be a stiff 'un.
If you're not bothered about the knob itself I say just get some mole grips on it!
tech1889
Serious forum addict
Mk2 GTI FTW !!
Re: Gearknob change
12 December 2010, 23:42 »
put ya back in to it mate.. it will twist off just may have a bit of glue holding it..
Mk4 Golf GTI anniversary and mk6 golf tdi
X4MGS
VAG Parts SNOB!!!
Re: Gearknob change
13 December 2010, 01:19 »
I had the same issue.... Mole grips on the stalk and put some effort into twisting off the KNOB...
All will sort its self out from there...
For More Info Click To See;
My Thread On Here
Or
My Ebay Store!
paul69
GTI forum regular
Re: Gearknob change
13 December 2010, 07:06 »
Ok, thanks guys.The car is my daily driver so I'm always nervous of doing some damage I can't fix myself. I will try harder!
dubber36
Forum addict
Re: Gearknob change
13 December 2010, 08:48 »
If you are going to use mole grips, put a rag round it to save damaging it. Someone will buy it even if it's only for a few quid. Every little helps.
rob.043
Here all the time
Re: Gearknob change
Reply #6 on:
13 December 2010, 09:16 »
Have you had a good look around the knob for any small allen screws? Some gear knobs have a wee screw to tighted onto the gear lever to hold it tightly in place. Remove any screws, then twist it off.
Golf mk2
Gearknob change
