Author Topic: Code 17840 -N112 interruption  (Read 2413 times)
Offline alexd
« on: 12 December 2010, 20:37 »
Hi all got my mate to scan my 1.8t yesterday and it flashed up with needing possibly a MAF, but also came up with this code
17840 secondary air injecting valve -N112 interruption
Now ive had a search but can't seem to find much info about fixing it, any one had this before?? Any info to point me in the right direction would be much appreciated  :tongue:
Offline old_n07
Re: Code 17840 -N112 interruption
« Reply #1 on: 12 December 2010, 20:57 »
From what I've read the N112 valve is part of the secondary air system which helps to quickly warm up the catalytic converter from a cold start. Either the valve has failed or the connector is disconnected/corroded, try reseating it and/or contact cleaner
http://wiki.ross-tech.com/wiki/index.php/17840/P1432/005170
Neil
Quote from: mikemk4golf
Hey you're a moderator, I want a serious answer not someone who takes the piss!
Grammar is the difference between Helping your Uncle jack off a horse and Helping your Uncle Jack off a horse.
Not so standard Gt TDi
Cluster Mods FAQ | Miles to Empty Guide
Offline alexd
« Reply #2 on: 12 December 2010, 21:10 »
Thats brilliant thank you mate don't suppose you know where either of those are located do you?
