Author Topic: Rear brakes  (Read 1866 times)
Offline jasona1989
Rear brakes
« on: 11 December 2010, 21:00 »
Am I correct in thinking In thinking I can put anniversary rear calliper carriers on with bigger discs and keep my standard callipers? ?
Offline Tazzy
Re: Rear brakes
« Reply #1 on: 11 December 2010, 21:03 »
stupid question maybe, but why do you want to change everything except the calipers?
If It Comes Off, Modify It!
Offline jasona1989
Re: Rear brakes
« Reply #2 on: 11 December 2010, 21:18 »
I know the callipers do all the work but surely a bigger area on the disc will help? And I know someone who has the carriers so would just need discs and pads
Offline vwfiend
Re: Rear brakes
« Reply #3 on: 11 December 2010, 21:38 »
The rear calipers have to be bigger, it's only the fronts you can get away with keeping the calipers going from 288 to 212mm IIRC
Offline richw911
Re: Rear brakes
« Reply #4 on: 12 December 2010, 10:31 »
^^ 312 mm  :laugh:
Yeah and 256mm vented rears  :smiley:
Offline tech1889
  • Mk2 GTI FTW !!
Re: Rear brakes
« Reply #5 on: 12 December 2010, 13:07 »
212 why you downgrading ??  :laugh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Rear brakes
« Reply #6 on: 12 December 2010, 13:26 »
I'm sure the pads on my 312mm were bigger too
edit, yes they are
« Last Edit: 12 December 2010, 13:28 by Wazzzer »
Offline vwfiend
Re: Rear brakes
« Reply #7 on: 12 December 2010, 13:30 »
Sorry, I have an iPhone and sausage fingers!  :laugh:  clearly 312.....
Offline tech1889
  • Mk2 GTI FTW !!
Re: Rear brakes
« Reply #8 on: 12 December 2010, 14:10 »
the pads are exactly the same aint they.. or do you use the TT pads ??
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Rear brakes
« Reply #9 on: 12 December 2010, 16:20 »
well those fill out the whole of the 312mm, I doubt they would fit the 288mm discs
