Author Topic: Is the repair kit for inner spotlamps still available?  (Read 1358 times)
Offline paul69
« on: 11 December 2010, 19:01 »
When trying to replace a broken inner spotlamps on my digi, the plastic fittings on the screws broke. I see from a search that vw do a repair kit but the posts were 4 or 5 years old so can anyone confirm that it is still available or should I try to bodge something with some bolts and nuts?
Also, as the grille was damaged along with the lamp when some toerag smashed into it, where would I find a replacement grille with the red line when I look to replace it?
Many thanks.
Offline h8v
Re: Is the repair kit for inner spotlamps still available?
« Reply #1 on: 11 December 2010, 19:11 »
GSF had them about a year ago.  I'm not sure if they are listed online, but give I'd suggest giving them a call to check.
h8v
Offline h8v
« Reply #2 on: 11 December 2010, 19:14 »
Just looked on www.gsfcarparts.com and it's part no 949VG0070,  £6.85.
h8v
Offline Thom89
  • Looking for an "Icebreaker"
« Reply #3 on: 11 December 2010, 20:31 »
One of our race cars runs the same lamps, adjuster kits were still available from VW at around a fiver a side...
A grill, you should be able to pick up easily in the Classifieds section of the forum, or ebay
Thom
Offline paul69
« Reply #4 on: 11 December 2010, 20:34 »
Thanks alot guys, much appreciated. :smiley:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #5 on: 11 December 2010, 21:57 »
Clips are NLA from VW & GSF...
I think I got the last 2 sets from Germany.. Did order 3 sets but they could only supply 2...
Try and buy a grille that has a good set of lamps on the bay etc...
For More Info Click To See;
