Author Topic: Brake Disc Relocater Screw  (Read 1270 times)
Offline Tazzy
« on: 11 December 2010, 17:02 »
ok, so its not important or life threatening, but its something that i like to be in place
noticed today whilst changeing both lower wishbone arms is that on the passenger side, the screw as broke inside the hub, so the disc moves around whilst the wheel is off
anyone know how to take out the broken thread so i can replace it?
thanks
If It Comes Off, Modify It!
Offline vwprime
Re: Brake Disc Relocater Screw
« Reply #1 on: 11 December 2010, 17:13 »
Lots of WD40.
You can eather try and nock it out with a chizal, if that don't work a drill is needed. Is quits soft metal and when started as long you have good drills should come out. tbh its no big deal and would just leave it mate for the hassel it is.
TRANSFORM, & ROLL OUT!
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 11 December 2010, 17:34 »
agreed it's not life threatening but it is a PITA when the disc spins round and blocks off the wheel bolt threads without you knowing  :angry: :grin:
Offline andc1
« Reply #3 on: 11 December 2010, 18:13 »
from past experiance mate leave it!!!!! it will only go wrong and there will be tears!!!!  :cry: :grin: :grin: :grin:
Offline houston
« Reply #4 on: 11 December 2010, 18:45 »
easies way is take off the disc, then you should see more of the threads showing and you can get a pair of grips on there.
but id just leave it, agree its a bit of a pain changing wheels but how often do you have them off? and the screw will just snap again anyway
Offline Ben Lessani
« Reply #5 on: 11 December 2010, 19:42 »
if theres 3-4mm of visible thread, a stud extractor should get it out easily.
I've drilled out a sheared off wheel bolt before and it wasn't that hard. Just make sure you've got good drill bits.
Offline Tazzy
« Reply #6 on: 11 December 2010, 20:07 »
thanks guys, ill leave it then, but is annoying
ive gota take the wheel back off tomorrow, somethings lose and rattling about, think it may be the disc gaurd, if not not, probably something more severe, lol, the rattling sure wasnt there before we changed the wishbone  :huh:
