Author Topic: Undertray Clip Question  (Read 6363 times)
Offline Ady TDI
« on: 10 December 2010, 12:27 »
The other day my undertray was hanging down and i have 4 missing torx screws :sad:
Also the plastic the undertray bolts to has the white plastic clip missing, does anyone know part numbers for the plastic clip and torx screws
Thanks
Offline Steve_PD
Re: Undertray Clip Question
« Reply #1 on: 10 December 2010, 14:05 »
Halfords may sell them, the clips are called spire clips then use some 6 or 8mm self tapping screws
Offline Steve_PD
« Reply #2 on: 10 December 2010, 14:10 »
Offline Ady TDI
« Reply #3 on: 10 December 2010, 19:20 »
Thanks Steve, i needed those as well, but the clip i meant is next to the undertray the undertray actually bolts to it, and far up in the wing there is a thread which a clip pushes onto to hold that bit of plastic up.
Not much of a description but will have to try and get a pic :smiley:
Offline Steve_PD
« Reply #4 on: 10 December 2010, 19:55 »
I know what you mean, round disc with a star shape centre cut out :laugh: not sure what they are called. pretty sure when mine broke I managed to screw a nut on it with a large washer. it done the job till a speed bump smashed it some more and I ended up buying a new section :lipsrsealed:
Offline Ady TDI
« Reply #5 on: 10 December 2010, 22:31 »
That's the one, at the mo i have removed the undertray and have put blu tak where this clip is meant to go :laugh:
Will put a nut on and hopefully wont come off.
Thanks mate
Offline asif
« Reply #6 on: 11 December 2010, 11:21 »
I just used some big ass screws which have done the job since just before summer, the undertray is a pain in the crack and expensive item to replace also.
MK7 GT Bluemotion Tech TDi 150
Offline Gareth F
« Reply #7 on: 17 December 2010, 23:44 »
Mine was hanging down and scraping at 70mph  :grin:
Popped into Vw dealership and bought the proper screws and clips for 20p - 90p each  :wink:
They also have exploded diagrams they can get the correct parts from.
No SmOkE nO pOkE....
Offline asif
« Reply #8 on: 18 December 2010, 12:01 »
It's called ETKA IIRC
Offline Neo Badness
  • Feet are for pedals
« Reply #9 on: 18 December 2010, 12:04 »
Cable ties FTW  :smug:
Worked for me
