Author Topic: random lights  (Read 1454 times)
Offline BobbyT
random lights
« on: 13 February 2005, 18:36 »
Hi, i own mk1 gti and have just fitted some clear lights but have found out that when you brake with the side lights on that the right indicator lights up (just a little mind) and when you use the reverse lights and brake it does the same! also my indicators some times work fine but other times the green light on the dash flashes alot faster than it should! what is going on? rob
Offline mk1
Re: random lights
« Reply #1 on: 13 February 2005, 18:47 »
Check the connection to the right hand light cluster, sounds like a bad connection (earth?). Check the indicator bulb is making a good contact.
Steve.
Offline Dizzie
  • Make friends with your fast
Re: random lights
« Reply #2 on: 16 February 2005, 15:04 »
definetly sounds like a dodgey wire somewhere. can't say where without having a look and checking connections.
Mk4 Golf 150PD
Offline Horney
Re: random lights
« Reply #3 on: 16 February 2005, 15:18 »
Sounds like a bad earth to me. Happens all the time on the bloody mini.
