Author Topic: help required 2.0 1.6v conversion  (Read 1050 times)
Offline pk2904
« on: 08 December 2010, 18:24 »
hi,
ive just finished installing a 94 9a carrodo engine in my  h reg mk2 gti.... using 1.8 16v kr loom from h reg aswel.... car fired up first time only problem is theres no feed coming to the idle control valve so it needs to be revved to stay on,,, bizzare to me, ive checked the fuse box all fuses and relays are fine any feedback will be appreciated.......
cheer p
Re: help required 2.0 1.6v conversion
« Reply #1 on: 09 December 2010, 09:35 »
so its running on kr managment? did you also get the isv control box and loom from inside the car, and if so did you hook up the black wire to an ignition live feed?
Offline pk2904
« Reply #2 on: 09 December 2010, 18:00 »
yes mate its running kr managment with the isv control and loom from inside........ thanks for the reply mate... got it running fine today there was a break in the wire in gthe loom that leads to the isv.
cheers p
