Author Topic: Scrubber  (Read 4436 times)
Offline Haribo!
Scrubber
« on: 08 December 2010, 10:47 »
Ive been through various lowering kits and decided to go back to standard 16v hight, now ive had 2 sets of shocks and springs on the rear so far, each have scrubbed really bad on the tyres onbumps or with passengers it is undrivable, I run on 195 50 15.
Is it likely the shocks or the springs or both?  Im tempted to just cut my arches but that seems like cheating and I cant be bothered with the fuss.
Offline rob.043
Re: Scrubber
« Reply #1 on: 08 December 2010, 11:16 »
How much was it lowered by? There is a guide in the maintinance section that gives the measures from the wheel centre to the metal lip of the wheel arch, so you can see how much its been dropped.
Could always ask your rear seat passengers to diet.
It will be spring stiffness that determines the ride height, but these should be matched to suitable dampers for stroke and travel etc.
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Scrubber
« Reply #2 on: 08 December 2010, 16:39 »
Your sign pic looks like the rear is sitting much lower than your front...
What set up do you have??
For More Info Click To See;
Offline Haribo!
Re: Scrubber
« Reply #3 on: 09 December 2010, 10:44 »
Ah maybe I worded it wrong, what i meant in my first post was that its now standard 16v height so not lowered as such.
Offline Haribo!
Re: Scrubber
« Reply #4 on: 09 December 2010, 10:50 »
yeh that pics from inbetween the messing about, thats supposed to be a 40mm lowered set but I couldnt understand why one end sat higher than the other (I wondered if it was meant for a carrado and maybe the front is heavier on those?) but when I measured it up I found that the front was standard 16v height so I just got myself some standard 16v rear shocks and springs to match and now the ride height is even, but it scrubs so bad on bumps, and with anyone in the back, even my mates fairly small girlfriend it scrubs on even the slightest of bumps
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Scrubber
« Reply #5 on: 09 December 2010, 11:13 »
Sounds like your springs are knacked to me...
I have Eibach springs which are 30mm lower than 16V springs and dont have an issue with two adults in the back!!
Offline Mr Blue
Re: Scrubber
« Reply #6 on: 09 December 2010, 12:25 »
You can get some spring helpers (forgot the name). I used some in the past to stop the front scrubbing.
They wrap around the coil. No need to remove anything to fit.
Might be worth a try first.
Offline rob.043
Re: Scrubber
« Reply #7 on: 09 December 2010, 12:34 »
So 16v height is 330mm from wheel centre straight up to the underside of the arch, and this is what you have now?
There certainly must be something wrong to get scrubbing problems with only light rear loading. Have you got reasonably fresh bump stops on the shocks? Are the top mounts in decent condition, not dropped/collapsed?
Offline Haribo!
Re: Scrubber
« Reply #8 on: 09 December 2010, 22:48 »
Looks like il get more springs, what a pain x x
Re: Scrubber
« Reply #9 on: 10 December 2010, 09:18 »
Standard set up should not rub so sounds like your rear shocks / springs are knackered.
