Author Topic: 2003> mk4 suspension?  (Read 1497 times)
Offline mikemk4gti
« on: 07 December 2010, 21:39 »
Hi, I've got a 2003 mk4 1.8t gti now, with the auq 180 engine 6 speed. Bigger brakes etc same as tha anni. so the question is, are the springs the same as the anni's (10mm lower) or just the normal from a gti?? Anyone know? I'm thinking if lowering so a 35mm may only be 25mm if there Anni spec.
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
Offline tech1889
  • Mk2 GTI FTW !!
Re: 2003> mk4 suspension?
« Reply #1 on: 07 December 2010, 21:41 »
think they are same as anni..
Offline dolphinfriendly1012
« Reply #2 on: 07 December 2010, 21:54 »
Don't know if this will help. Go through your service book and take all the codes on the sticker and enter them into this site, should tell you what they mean and what suspension is fitted
http://igorweb.org/equidec/Default.aspx
Also my old bora was a 180bhp model with 6 speed box and bigger brakes and came with sports suspension as does my current v5 but neither was particularly low.
Offline mikemk4gti
« Reply #3 on: 08 December 2010, 20:01 »
never thought of that!
 Well the code is L19 = Suspension range 19 installation control only, no requirement forecast
and my anni was L28 = Suspension range 28 installation control only, no requirement forecast
think this is the right bit, so there not the same.
