Author Topic: mk4 head  (Read 2263 times)
Offline mar_k
mk4 head
« on: 07 December 2010, 19:24 »
it was mentioned on a different forum that the mk4 2.0 8v head cant be skimmed because the injecter rail is difficult to remove,
and once removed its even harder to refit.
is there any truth in this or is it compete bull.
Offline vwfiend
Re: mk4 head
« Reply #1 on: 07 December 2010, 21:05 »
Sounds ridiculous, what if the injector rail fails......
Offline tech1889
  • Mk2 GTI FTW !!
Re: mk4 head
« Reply #2 on: 07 December 2010, 21:07 »
if it fails then its a sh!t job to replace lool
Offline vwfiend
Re: mk4 head
« Reply #3 on: 07 December 2010, 21:08 »
Anything is do-able, I love a challenge. Rise to it!
Re: mk4 head
« Reply #4 on: 07 December 2010, 23:34 »
Cannot see it to be honest, I know someone that has replaced the hg and had the head skimmed all ok with no issues.
Offline houston
Re: mk4 head
« Reply #5 on: 07 December 2010, 23:43 »
its the same engine as in he mk3 isnt it? if it is then its no worry
Offline vwblackmk4gti
Re: mk4 head
« Reply #6 on: 08 December 2010, 12:33 »
when i used to work at vw, i done the head gasket on a 2.0 8v with no problems. the head was sent away for skimming but i still had to strip the head down..
Offline mar_k
Re: mk4 head
« Reply #7 on: 08 December 2010, 19:35 »
cheers guys, i kinda expected to hear what your saying.
i think my dads headgasket is on its way out as he can smell exhaust fumes coming through the vents when the blower is on.
will be stripping it down over xmas
Re: mk4 head
« Reply #8 on: 08 December 2010, 19:59 »
before you strip it make sure it is the problem, conduct a sniff test or compression test. i've seen it so many times when some one just goes on a guess. and ends up with a different problem,, diagnose it first fella,, may save you money in the long run
Offline mar_k
Re: mk4 head
« Reply #9 on: 08 December 2010, 21:42 »
will be getting a sniff test done this saturday to confirm it however it does use alittle water with no visable signs of a leak.
cheers
