Author Topic: Interior light staying on  (Read 1013 times)
Offline Hulmie
  • White MK4 1.8T AGU K03s
« on: 07 December 2010, 16:56 »
When i lock the car up normally all interior lights should go out. but now the ones at the front of the car are dimming but not going out?
What could be causing this? Possible bad earth? Only changed the battery over on friday
Offline vwprime
Re: Interior light staying on
« Reply #1 on: 07 December 2010, 17:50 »
Have you had problems with the doors locking and unlocking also after you open it?
Im thinking the modual thing in the door, as my friends any is doing somthing simler and has had to switch the lights off to the 'OFF' in the car.
TRANSFORM, & ROLL OUT!
Offline mikemk4gti
« Reply #2 on: 08 December 2010, 20:32 »
probably be easiest to get vag com on it first to see if theres any faults :)
51 mk4 gti 1.8t AUM | 05 Audi A3 3.2 Quattro S-Line | 01 A3 1.8t Sport | 02 Golf 25th Anni 1.8T | 03 mk4 GTI AUQ | 05 Leon Fr TDI 150 | mk2 golf gti 8v | 01 Audi S3
Back in my old MK4 '01 AUM!
http://uk-mkivs.net/forums/t/400214.aspx
VagCom, VagTacho, MTE, Needles, Key coding, Locked beeps etc availab
jamie16v
« Reply #3 on: 08 December 2010, 20:52 »
doubt vag com will pick up this fault.
it could be either a dodgy micro switch or dry solder joint in the door lock module.. have a search to find the thread but pay particular attention when re-assembling and dont make the same mistake i made!
